Old 05-20-2014, 08:25 AM   #15 (permalink)
user removed
The video showed me on critical piece of information. The machine is "balanced" only being held by my hand. It has no reciprocating parts. In fact it is more like a turbine than a compressor or IC engine.
That means you could replace the turbine blades (think torque converter) with two of these machines and you would have a positive displacement turbine. The model does not have the adjustable off set journal that is shown in the patent, which allows the stroke position to be adjusted While THE MACHINE IS IN MOTION.
In an IC configuration that means "on the fly' adjustable displacement as well as variable compression.
regards
Mech
