Originally Posted by mikeyjd
There is 4 inches of fiberglass insulation in between it and the coro. So.. 4 inches.
A few questions...
-What exact type of fiberglass are you using?
-Is it going to retain moisture?
-Pics?
I ask because you might find some issues with it retaining a lot of moisture and causing advanced corrosion on your exhaust piping (and possibly the body of the vehicle itself). This will also keep a lot more heat on your exhaust piping, which has it's ups and downs (though I'm not really clear on the downs, honestly. A bit of research might be needed here).
I wrapped it in fire retarded fiber glass. I ended up adding some venting in the rear as the summer temps require better air flow, and it can cause issues with the gas tank becoming a safety hazard if the temps go to high.
I think you meant: Fire Retardant.
(lol, reminds me of this..)
