Originally Posted by NoD~
A few questions...
-What exact type of fiberglass are you using?
-Is it going to retain moisture?
-Pics?
I ask because you might find some issues with it retaining a lot of moisture and causing advanced corrosion on your exhaust piping (and possibly the body of the vehicle itself). This will also keep a lot more heat on your exhaust piping, which has it's ups and downs (though I'm not really clear on the downs, honestly. A bit of research might be needed here).
I think you meant: Fire Retardant.
(lol, reminds me of this..)
![](http://t.qkme.me/3lcd.jpg)
White faced batt insulation. I checked on moisture after a few drives during heavy rainfall and it was damp but not soaked so I didn't worry about it after that. After having it on for a while it seemed to be retaining more moisture, so i think a better solution is needed.
![](https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcRRnlfKaAbUnB-6SPaHvdeOJ-M2r1ce16pfrSRlmr71HZO2LnDV)
