Old 05-20-2014, 02:29 PM   #30 (permalink)
Daox
Another month, another list of interesting things.
1) Passive cooled house in the tropics
A very interesting house design that minimizes radiant heat gain to a large degree.
Passive cooled house in the tropics - EcoRenovator
2) Cheap window reverse cycle ac build
Check out Jeff5may's modification of a window A/C unit into a window heat pump for heating and cooling.
cheap window reverse cycle ac build - EcoRenovator
3) My DIY cellulose wall dense pack experience
Exeric shares some very helpful information on DIY dense packing his walls with cellulose.
My DIY cellulose wall dense pack experience - EcoRenovator
4) Ventless washer and dryer vs high efficiency dryer and washer
Nokiasixteth asks about the difference between a ventless washer and dryer and a high efficiency washer and dryer.
Ventless washer and dryer vs high efficiency dryer and washer - EcoRenovator
5) What is your average kWh/day usage?
An oldie, but a goodie. How much electricity do you use per day? Compare with other ecorenovators.
What is your average kWh/day usage? - EcoRenovator
The Following 2 Users Say Thank You to Daox For This Useful Post:
California98Civic (07-05-2014), mikeyjd (05-21-2014)
