Old 05-20-2014, 04:45 PM   #380 (permalink)
josemapiro
Originally Posted by t vago View Post
Yah, it was a challenge to find some suitable icon for the microsecond functions. Microsecond functions are really only meant for the serial logging output, they use the same 64-bit computation engine (SWEET64) as the other functions, and I didn't want to further complicate the code by trying to disallow microsecond function output on the display screen.
Changing the microsecond function icon is going to be a fairly low priority change to implement. Must put in RTC support, improve the menu, and add A-B test viewing and coastdown testing first.
Ok
I just gave this idea to see a menu with the icon different than usual, follow the order you want, because they do not have any problem for me is how the icon.
Thank you
José Rodrigues
The Following User Says Thank You to josemapiro For This Useful Post:
t vago (05-20-2014)
