Old 05-21-2014, 08:06 AM   #48 (permalink)
BarelyAWake
BarelyAWake's Avatar
Originally Posted by vskid3 View Post
I've put about 150 miles on it since converting. Everything is working great...
Congrats! There's just something wonderfully addictive about ebikes
My biggest complaint is the battery on the rear rack, just too much weight back there... I think mounting the battery would have been easier if I'd ordered the it split in half
It's not too late if you're feelin' handy - the cells within the pack are pretty much what you'd expect, each has a single positive & negative terminal & it's just a matter of lengthening the wiring for the cells & BMS feeds you'd like to relocate. The Ping 48v 15Ah LiFePO4 you've got likely is the same as mine, so it's got the round cells in a plastic rack with a terminal at the top & bottom, they're a bit bulkier then the flat cells but are easier to work with.
Here's a coupla pics of what's inside the wrap - first pic (not mine) would be very similar cells to what you've got, minus the wiring & BMS ofc & the second is the flat cell design, included to show wiring;
You'd just need to label each wire & the cell it goes to while modifying, it only seems daunting at first... but... unless you've sorted out a way to put the pack within the frame's triangle, it may not be worth the effort.
When I first threw Mongo together I just stuffed one pack into each side of the panniers. While the weight is lower then on top of the cargo rack when I later changed panniers and relocated the pack to the top of the cargo rack I learned it didn't make that much of a difference - it does help some to have the weight lower, but as it's still behind the bike's center of mass it still feels odd, even a little sketchy on slippery surfaces & a hard turn (wet leaves/painted stripes/etc).
I can say however it is something you get used to, it isn't as bad as it may feel at first - it's actually only 16lbs or so on the rack and interestingly that "top heavy" feeling goes away as soon as I put stuff (groceries or w/e) in the panniers.
At this stage I'd humbly suggest you just continue on doin' what you're doing, riding & enjoying the thing lol - if come next season you're still not used to it, odds are you'll be lookin' to modify it anyway
*whispers* get rid of that ax head torture device they call a "saddle" man, yer not pedaling so much anymore
