Looks nice.
You will see a slight FE increase from lowering. Problem is 2 inches is too much at times (I was at 2.5). Without a sway bar, if you hit a bump mid-corner, it'll bottom. I've since lifted my back up. The easiest way to go slightly lower and keep a good ride, is grab the stock shocks, springs and forks off of a EF (88-91).
Oh, and can the mudflaps.
Shooting for 600 miles of range at 65-70 mph out of a vx.
