Old 05-23-2014, 12:25 PM   #6 (permalink)
color0
Not entirely mpg's
Thanks for the welcome guys!
Originally Posted by elhigh View Post
It looks to me like the rounded rear edge of the D-pillar is probably inducing a fair amount of turbulence at flow separation, you could add some small Kammback extensions to those and clean that mess up a bit, maybe add an extension also to the roof edge for the same purpose. If you're competing on track days you'll want to dig into the rules to keep everything kosher with the Tech guys.
For the most part I'd like to avoid large new pieces in the rear just from an aesthetic standpoint, so I was thinking a couple rear spoiler fill-in panels (don't know the technical term... think Mazda CX-5, under its hatch spoiler) and trying out VGs just aft of the rear quarter window.
For track days I assume you're already pulling all the unnecessary weight out of the car? Passenger seat, rear seat, spare tire? The less mass you have to drag out of the turns, the better.
I unfortunately have to leave most of it in, except spare tire. The Mazda3 rear suspension toes out as you lift it up, so when my normal alignment is 0.00toe all around, taking everything out for the track makes the rear end VERY sketchy under braking. I just kinda deal with it as tire wear and street mpg's are more important to me.
Have you thought about a removable grill block ? On during the week, removed for track days. It's usually worth about 5% and should get you back to 40.
As soon as I figure out a clean way to do it. Thanks!
