Old 05-23-2014, 10:09 PM   #122 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by mcbota View Post
worthy to coast in neutral from stop light to stop light, or in gear ( in gear is harder, the distance between stop lights being around 250-500 m)? I am not sure how is the thing with ”load and low rpm” and how can I realize this without being too low in rpm! I stilll learn and I thank you for being good teachers!
Keep it in gear if you need to stop. My T5 uses less fuel gliding in gear than coasting in neutral even factoring in the engine braking (I would have never thought this was possible previously - but it's heavy ~1900kg with a full tank & driver, fairly aerodynamic [0.33cd] and of course being a diesel there's little engine braking to speak of, esp in sixth gear at 1000rpm - it will coast a really long way). Keeping it in gear also means I can do micro pulse and glide, only droping speed by 5km/h, this method is working better for me than engine on Neutral coast, and it can be done even in heavy traffic.
If I'm driving in 4th or 5th and want to glide, I'll upshift to sixth to minimise engine braking while staying in DFCO. If I'm turning or see slow moving traffic ahead and know I'll need 3rd gear, I down shift ASAP so the gear is ready when I need it, the modest increase in engine brake saves the friction brakes, and the higher RPM means I stay in DFCO longer.
For load, low RPM= high load (generally), my T5 cruising on level ground at 60km/h & 1100RPM is already at 80% load. At 1300 RPM (5th gear) load drops to 65. If I didn't have a Scanguage I'd suggest keeping the revs at 1200-1300.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
mcbota (05-24-2014)
