Old 05-24-2014, 01:23 AM   #4 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
removing lowest PS line
Originally Posted by cbaber View Post
Remove PS belt. Jack up the car, get an oil pan and put it underneath. Disconnect one of the PS lines let the fluid drain out. Not all fluid will come out, so you will need to sit in the car, turning the wheels side to side (fluid will spray out with steering pressure). Repeat until you no longer see fluid coming out.
Then simply reconnect the line and you are done.
Cbaber, where did you remove the line, from under the car or above?
