Originally Posted by johnlvs2run
Cbaber, where did you remove the line, from under the car or above?
If I remember correctly I think it was one of the lines above. Either I didn't have access, or I couldn't get the lines off on the lower ones easily. I had to rotate the steering wheel side to side for a couple minutes to force as much fluid out as possible.
