Old 05-25-2014, 07:20 PM   #5 (permalink)
cRiPpLe_rOoStEr
Maybe it would be interesting to replace the rusty panels with some fiberglass, both due to its lighter weight but also to eliminate rust issues.
Originally Posted by ecomodded View Post
Could buy a Sprint or firefly and use its drivetrain
With a turbocharger and an intercooler it would be great. It may even not feel so underpowered without them, but a well-tuned setup would allow it to be kept at lower RPM while cruising. Nowadays even the turbo-lag issue is easier to overcome
Or a tdi and join the diesel crowds mpg savings
Or if you would go with a TDI there is also the opportunity to convert it to also run on vegetable oils.
