Well, if its got lean burn you should be easily able to push triple digits. Most of the gen 1 insight guys can get impressive mpg with careful use of the ima system, but even more with lean burn.
Ive fooled around with the gen 2 insight and it seems best mpg is from not using the ima system and like using cruse control for constant speed.
