Old 05-26-2014, 08:41 PM   #4 (permalink)
Davo53209@yahoo.com
Originally Posted by xntrx View Post
Is it lean burning, and if so, how wide is the lean burn "window"?
Hunting idle is electrical load (general or a short triggering the ELD), or a vacuum leak. The later will kill the lean burn window.
That's another issue. I really don't if or when it's in lean burn mode. In fact, I don't know how to recognize that mode. What I can tell you is that when traveling at 65mph, the needle on the tachometer hovers around 2000 rpm.
