If wheels had fan like blades should they pull or push air?
If wheels had fan like blades should they pull air in the car wheelwells or push it out of the car?
I think for brake cooling they should push air out of the car.
Some racecars use ducts that route air out of the car.
For lower aero drag Would pulling air into the wheelwells reduce drag as it removes the boundary layer and turbulence outside the wheels?
