Old 05-27-2014, 07:17 PM   #12 (permalink)
aerohead
blades
Originally Posted by Big time View Post
If wheels had fan like blades should they pull air in the car wheelwells or push it out of the car?
I think for brake cooling they should push air out of the car.
Some racecars use ducts that route air out of the car.
For lower aero drag Would pulling air into the wheelwells reduce drag as it removes the boundary layer and turbulence outside the wheels?
For low drag,you'd have no blades at all,only a convex,full disc wheel cover as MOON produced.For cooling issues,you'd have some porosity near the rim.
The GM Ultralite demonstrates an optimized design.
