Old 05-27-2014, 09:46 PM   #124 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
spoiler spoiled!
So, in the case this design might actually work, as in a different approach instead of building to the proper shape from the top(canopy wise), i decided to start from the bottom up... Well, more like, filling-in the dead zone along the trunk area...
In all I've been able to witness driving, it's working, albeit ...ugly.
I can see a definite reattachment of airflow around the back, and a lack of vortex generated from the central antenna and D-pillars ..Yay While not able to gain more speed/distance during coasting as the Full Kamm, i coast longer, at a more steady speed, so still an improvement
^^still have all the flexibility to adjust the length of "spoiler" to actually match template, but i don't think that would change much, reattached flow seems to be good, with consistent separation top and sides
Still indecisive about side skirts, but i do have rear wheel strafes in front for now
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The Following User Says Thank You to RiderofBikes For This Useful Post:
aerohead (05-28-2014)
