Old 05-28-2014, 06:28 AM   #23 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by mcbota View Post
Today, I have made a trip with my car, mostly on roads which passes through villages, so , one way I drive almost steady with 70 kph, in fifth gear, and the route back, I have made pulse and glide, 80/60 kph, in fourth gear, the consumption, one way was, 3.8 l/100km, and back 2.9 l/100 km; is this a good method, the clutch isnt affected too much, will be no problem with it? It was the first time when I tried this method!
Since your car is a diesel with little engine braking, try pulse and glide IN GEAR. It's a lot less work and gives me roughly 15% improvement.
Your 25% improvement is huge, I feel other factors were involved (tail wind or elevation differences, or P&G fooling the OEM display as with my Fiat), but yes P&G really works. The gearbox & clutch will be OK as long as you rev match before shifting back into gear. I'd also suggest shifting into neutral without using the clutch, just back off until the gear lever is easy to shift out (works better on some cars than others).
But IMO this is really a petrol car technique. For my TDI both methods give the same result, so I'm using the easier method.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
mcbota (05-28-2014)
