Originally Posted by mikeyjd
if you were able to do the 80/60 pulse in 5th gear rather than 4th.
At 60kph the rpm when I put in fifth gear, seems to be too low, and for this reason I have tried with fourth gear. I will try with fifth gear, and in city probably, iwill try to make 60/40 kph with fourth gear. I was thinking that can be an optimal load for the gears!
