Originally Posted by xntrx
and a lot of the Jalopnik poster commented the same.
but the delta wing is actually quite stable. It has a massive rear weight bias, so the center of gravity is pretty much just in front of the rear tires.
THat was the whole premise of the thing. Only put as much track width and tire as the weight required.
wheras the robin had most of the weight above that single wheel
