Old 05-29-2014, 02:28 AM   #1 (permalink)
Davo53209@yahoo.com
Broken Bolt/EGR Valve
As I was attempting to remove the EGR valve off of my Civic Vx, one of the two nuts that holds it down, had broken off of the left stud. The right one however came off without a problem.
Upon first inspection, it appeared has though I could drill this out; but then started to wonder if both of these studs were welded in place.
In closing, it appears to be a part that can be separated; but before I go into any more trouble, I'd to know if that fact can be confirmed. As for now, I have sitting soaked in WD-40 oil for at least tomorrow.
