Clear Lexan* Polycarbonate 9034 Sheeting
Lexan* 9034 uncoated polycarbonate sheet is the standard grade of Lexan* sheet for transparent protective glazing. High-impact Lexan* 9034 sheet can be utilized for primary glazing, or on either side of existing glazing for economical protection against breakage or intrusions. A better insulator than glass, Lexan* 9034 sheet contributes to lower energy costs. It is virtually unbreakable, making its products an excellent condidate for safety in areas where parts may be exposed to high impact. Will withstand -40° to 180° continuous and 250°F short term with no load. Forming temp. is approx. 375°F. Excellent thermoforming characteristics. Cold form radius no tighter than 100 times the thickness of the material. Superior fire performance. UL listed for burglary resistance. No UV treated surface. Typical applications include interior applications for industrial and commercial, interior glazing in security areas, fabricated parts, industrial machine guards and much more. *Lexan is a registered trademark of General Electric Company. Not FDA compliant.
The second concerns me more than the first bold.
