Old 05-30-2014, 12:41 PM   #278 (permalink)
Grant-53
The automotive clear finishes in the basecoat-clear coat systems used on most vehicles are UV resistant. So clean the Lexan with dish soap and water. Rinse and let dry then wipe with a tack rag. Spray a couple light coats of clear acrylic enamel or urethane finish. Practice on some scrap material first to get a glossy finish. If needed, polish the fully cured surface with a very fine polishing compound. Teflon coatings such RainX can reduce wear from windshield wipers. Clean the windshield and wipers often to remove grit that can scratch the plastic.
The Following User Says Thank You to Grant-53 For This Useful Post:
renault_megane_dci (06-02-2014)
