Old 05-30-2014, 03:30 PM   #2 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Once you drain the fluid, is it as simple as connecting the hose where you want it?
The hose that comes out of the canister is a different size, which is removed first, then the canister is removed, as shown in the instructions here. The hose that goes into the canister is the same size as the hose with the metal line that comes out of the pump.
I drove the car a few days before connecting these two lines together, then connected them with the barb and didn't notice any difference. The main thing is to disconnect the lines from the pump, remove as much fluid as possible, and remove the belt.
