Old 05-30-2014, 04:16 PM   #5 (permalink)
zingaro
zingaro's Avatar
z - '13 Honda CRZ
Global - '12 Dodge Ram Cargo Van
nothing more nothing less
a little more n a little more
a little less n a lot more
NOw that the temps are coming up the air density is decreasing: good for the aerodynamic but bad for the performance. Between my home and a flea in SC theres a 6 % grade. Great going down but now going up I have to use 4 th gear instead of 5th. Im still running the blocking plate in front but because of the high IAT the ignition retards to below 10 degrees BTDC so I cant maintain 52 mph in 5th gear. I usually downshift before the ecu shows the downshift lite ( I think it comes on at 6 degrees BTDC)
IN the pic below the SC is showing 31 degrees ignition timing but if I could of caught the whole panel youd see one bar of charge
