Old 06-01-2014, 03:02 AM   #105 (permalink)
ctgottapee
the old boat - '93 Cadillac Deville *removed/modified
90 day: 24.2 mpg (US)
I'm guessing you measured correct.
My stereo is the largest wattage use outside of the fan.
Headlights are down to 40watts, the stereo jumps around but is 25-110w with some larger peaks. 25w is when its off with car running - appears to be a bit wasteful, but not really in the realm of things for an auto. The always hot line to it has a 2amp fuse so 25w is about right.
Still hooked to four speakers, prob try disconnecting the rears.
