Originally Posted by mrmojo
2. Re: calibration and accuracy: If the factory speedo is out of cal , whether by design or not, it seems like calibrating the UG using mile markers would provide more accurate FE data. But I'm hesitant to use those numbers when I post in the Garage, as I started off using factory odometer miles/petrol station gallons. If I started posting the UG data, I'd look like a FE god without doing anything but changing my data source.
I see no reason not to use the more accurate information. Note the percentage difference for the miles if any then you can apply that to your old numbers for a more direct comparison.
3. The number of gauges is rather overwhelming. I monitor the basic parameters, but there are many others which may help my FE, and I am ignorant as to which would be helpful.
4. Anybody have a lot of experience with UG that has set it up have any advice which parameters are more useful for FE?
Everyone has their favorites. Instantaneous FE, Load and GPH are some of what is on my first page. Instantaneous FE is the most watched for me.
5. I wish I would have checked out the UG website in more detail before I bought the gauge; they have sections for installation videos, usage videos, and even a form. Problem is, the video sections are "Coming soon!" and the forum has been closed! To me, a company that sells an instrument with this much ability should be able to help out the buyers as advertised. Just my 2 cents...
Yep, the general forum is close, only the install seems to be open. Probably the Admin got tired of all the I can't get it to work posts. Wonder if the Android phone are taking a bite out of business.
