Originally Posted by nemo
I see no reason not to use the more accurate information. Note the percentage difference for the miles if any then you can apply that to your old numbers for a more direct comparison.
That's a good idea; time to fire up Excel.
I know one reason for the difference was the distance calibration; the cal factor went from 1.000 to 0.996.
Everyone has their favorites. Instantaneous FE, Load and GPH are some of what is on my first page. Instantaneous FE is the most watched for me.
How does load help? I've also read about throttle position (TPS), but again, my ignorance comes to the front of the line.
Yep, the general forum is close, only the install seems to be open. Probably the Admin got tired of all the I can't get it to work posts. Wonder if the Android phone are taking a bite out of business.
Why would Android take a bite out of business? Is there an app? Does someone make a connector cable? Tell me more, tell me more!
