Old 06-03-2014, 11:32 PM   #21 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by Old Mechanic View Post
Maybe you can still get a box end wrench on the fitting so you can tighten the line without stressing the weld, squeezing the wrenches together. Take an old wrench and grind the side of the box end down if you need some clearance, but you probably already know this.
regards
Mech
Thanks Mech
What you describe "squeezing the wrenches together" is what has so far worked good for me. Luckily the 10 AN doesn't take a whole lot of torque to seal her up. Not much pressure on the return line to the oil pan.
Thanks for the input guys!!!
Pressure Gradient Force
The Positive Side of the Number Line
