Old 06-04-2014, 05:29 AM   #7 (permalink)
cowmeat
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Thanks for the pix, that looks pretty damned professional compared to mine, wish I had checked it out before I did mine now. And it looks like you could remove yours easily.
I checked out your build thread and that rear lexan part of the kammback was a cool idea, very functional!
Where'd you get the sheet aluminum you used, and how much did it run you?
I will eventually get around to applying a rubber strip to cover the tape & bolts where the wheel well meets the skirt to make mine a little more legit. Since I can change the tire without disturbing the skirt, I'm going to make it a permanent fixture.
I like your front air dam, too. Been thinking about adding one, it might be hard to hook up since my bumper is mostly soft plastic and foam, but I'll come up with something.
