Old 06-05-2014, 12:22 AM   #4 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
open vs closed
Originally Posted by NoD~ View Post
If you leave both lines open and you turn, you are pumping air out one into the open air and sucking air into the other. With the line looped, it should lessen this effort.
Isn't it the other way around, easier to pump air through open lines, than pumping fluid back and forth through closed lines, and the only reason for looping is keeping any crude out.
