the higher RPM's do work, because the energy required is divided among more events. The heat is less concentrated, and as stated before the cooling system is running at a better flow for the heat.
I deal with this phenomenon with my Cummins-powered Dodge truck.
It makes huge amounts of torque at 1700, but the heat will build rapidly on a hill. If I get it to 2100 or so in the lower gear everything is cooler.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
