Old 06-05-2014, 05:20 AM   #7 (permalink)
Xist
I removed that plate and could see the other lines, but there is not any way to access them, and since they are metal, I wonder if I would be able to connect them without dropping the rack.
It took a while to wrestle my bad alternator out of there and get the new one in. It looks like they assembled the bolt hole wrong. There is a sleeve that has the end sticking out between the two metal pieces, but it is on the outside on the new one, so it does not fit! In the morning, I am going to remove it, hit it with a hammer, and see if I can get a sleeve to slide out of the way. Seriously?!
I guess that I could take apart my brand-new alternator and reverse that sleeve...
