Old 06-05-2014, 09:24 PM   #29 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Thanks for the advice.
The high pressure turbo is a 13g that came stock in the automatic transmission
Talons. I tested it by itself and it has full spool around 2800 rpm. IM using the stock
oil feed line that comes from the stock location on the head.
The low pressure turbo is feed from the oil filter housing. Im using all Forced Performance lines that came with the turbo. This turbo has a built in restrictor. I think its around .050 ?
Im up camping right now and will have to check it out Friday?
Pressure Gradient Force
The Positive Side of the Number Line
