Electric boost
I was considering the idea of an electric motor that you could pair up to an existing under-powered gas engine for some 'grass roots' power when needed, say when pulling out on the freeway at the press of a button or switch. Something that wouldn't necessarily void a warranty. The idea came from my Dad's 2012 Tacoma, which of whom's 4 cylinder engine is more of a work horse than a high revver. Any ideas? Thoughts?
Also, the use of super capacitors to charge the battery pack needed to run this electric boost motor, in a full power and or full charge configuration. Any experience out there?
