MetroMPG had to crank the handle on this page for a whole page before it took off...
EDIT: ideally you would use the sun at sunrise/set, but good luck finding such a wall/unobstructed sightline.
I like this best. A turn-out on Highway 101 at sunset, and a 4x8 sheet of white coroplast (folded in half for transportation). Use an East-West shadow to judge exactly when the light is horizontal. Trace 1/2 on one side and the other on the obverse.
Then fill it in with a Sharpie, photograph it, put it in the GIMP, crop it to a bounding box, blur it to infinity, sample the resulting gray, convert the RGB to a percentage and take that area of the bounding box. Done.
