Old 06-08-2014, 12:51 AM   #28 (permalink)
mbolton1990
mbolton1990's Avatar
eco-crx - '90 honda crx hf
90 day: 56.89 mpg (US)
lol Dont be so gracious.
Heres the head
96 00 Honda Civic EX 1 5L SOHC Dual 3 Stage V Tec OBD2 Head JDM D15B w Solenoid | eBay
Sorry to derail thread,in the name of leanburn I apologize.
EDIT;
I'm getting a hunch that since normal V-TEC can be manually engaged with +12V at the solenoid beyond the set RPM (5200 etc)and with the right oil pressure that VTEC-E should be able to be engaged the same way on that head.I'm thinking of a in-car switch that would kick off the VTEC-E solenoid and then wire that switch to manually change the AFR to 20:1 via a modified/flashed ECU.The benefit of this is that I would still be able to be on OBD-0 in my HF and would just have to re-wire a few sensors/dizzy and it *in theory* would work...
Hmm more research must be done.
EDIT EDIT;
ahh
So here's the ECU you got?
http://www.ebay.com/itm/96-97-98-HON...82d713&vxp=mtr
