Old 06-08-2014, 09:52 AM   #64 (permalink)
Daox
I tried the heater test yesterday. It seemed to blow very hot air. I then revved up the engine and there was little difference. So, it looks like I'll be flushing the radiator later today.
I also noticed the auto trans not shifting into gear as crisply as before. When I was under the car the other day, sure enough, I saw the trans pan leaking fluid. So, I went to the autoparts store and got a gasket and filter (who knows if its ever been changed), and some trans fluid. One more thing to do...
The final thing that I'd like to do with the car fixing wise is the passenger side door doesn't unlock and lock with the key. I'm not sure if thats because of the passenger door damage (its wrinkled up a bit, not horrible), or what. Its not a huge deal, but it is an annoyance.
After all that, the car should be mechanically sound.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (06-09-2014)
