Old 06-10-2014, 12:30 AM   #34 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Here was the wire frame I welded up. The curved center part is just a brace to hold it in shape. Imagine dacron being stretched across the outside wires. I hand sewed the fabric on and used a heat gun to draw it taunt. Just laid on some composite reinforcement, I think I had some 25 oz carbon cloth so I just used one layer. Spray glued it to the outside and painted on some epoxy. Once cured just peel it off.
Here is the wire frame.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
aerohead (06-10-2014)
