Old 06-10-2014, 02:28 PM   #23 (permalink)
oil pan 4
Originally Posted by ecomodded View Post
What a Lark , the fuel gets all the oxygen when being sprayed threw injectors (about 45psi) or Jets on Carburetors ( 4-15 psi est.)
I did not see how many psi he uses for his pressurizing ( fail ) experiment , regardless of what psi he apparently used it would do nothing other then feed the fuel faster for a quicker drain, if anything at all.
Drill into the fuel tank ? now that's good advice..
Actually carburetors run essentially 0 psi.
The very common 4.5psi of fuel pressure just gets the fuel up into the carburetor bowls.
The fuel bowl float or floats regulate fuel level in th bowl.
If the float or orifice some how fail or if the fuel pressure is too great fuel just starts dumping into the engine through all these little passage
There it sits at atmospheric pressure untill the fuel is drawn through a jet.
The only fuel that developes any pressyre once it reaches the bowl is fuel that gets pushed through the accelerater pump.
ecomodded (06-10-2014)
