Originally Posted by Cobb
Thats not any part of a limited slip I have seen.
the big holes line up with the driveshafts, the small hole rides the pin in the center of the pinion. when installed, you popoff the 2 clips in the picture. it's spring loaded, and it will put torque on the driver side driveshaft
