Ok, I got ya. Its a spring loaded clip that applys drag to the back side of the spider gears.
Im use to the ones that use mutiple mini clutch disks to limit or air pressure to lock it.
I bet that will work in a range of hondas or other vehicles.
Originally Posted by vrmouseyd15b
the big holes line up with the driveshafts, the small hole rides the pin in the center of the pinion. when installed, you popoff the 2 clips in the picture. it's spring loaded, and it will put torque on the driver side driveshaft
