The air dams especially the garden edging comes down to the point where its just about level with the front Axel. Because of the body lift configuration i wouldn't loose anymore ground clearance with them on or off since all the suspension components are in the same placement in height. The only thing that lifts the truck higher over all is the bigger tires which is like maybe an inch if that. And no this specific ranger doesn't have a skid plate over the oil pan. Ive seen some rangers in this year that had them but not a lot of them. Thought about getting one.
