Thread: What lead-acid?
Old 06-11-2014, 01:06 PM   #18 (permalink)
oil pan 4
4 cells shouldn't need a balancer. But I bet it wont hurt.
Anderson connectors are rated for continuous use. On a low duty cycle say for something like a vehicle starting application you can safely put double the rated amps through it.
I used double anderson connectors in the suburban. I mainly just needed an anderson connector that came with a pin that could accept 2ga cable.
I have a 200 or 250 amp anderson in the camaro, it uses 4ga wire.
