Thread: What lead-acid?
Old 06-11-2014, 03:47 PM   #21 (permalink)
RedDevil
90 day: 54.23 mpg (US)
As the graphs show the cells will take charge up to very nearly full at less than 3.5 Volt per cell.
The Insight powers the 12V system from the IMA DC-DC converter. It switches between two states: about 12.65 Volt and 13.90 Volt (resting and charging the LA battery) but I also see peaks and dips in that voltage.
I will only know what it does to a LiFePO4 pack if I hook that up. It can go to 14 Volt so I assume it can get it to near 100% SOC, but otherwise I have the panel to top it off
