Old 07-10-2008, 10:30 PM   #6 (permalink)
NismoMax80
NismoMax80's Avatar
Max - '04 Nissan Maxima SE
90 day: 24 mpg (US)
does anyone know if it's possible to glue polycarbonate to itself?
i'm thinking of adding air dams under the underbody tray i'm adding. not sure if having a narrow strip at a right angle is even possible?
maybe i could use gorilla tape on both sides. oohh, if i can find some small L brackets i could screw it together. and the tape would reinforce it!
so i guess my real question now:
since my tray will be so low to the ground, will an air dam underneath be effective?
the oem tray had one, but mine will reach 7" further back. it is also further forward and closer to the ground. this tray will actually be lower than the stock tire air dams. i'm kind of concerned if a 1" one would be scraped off?
my current project
