Old 06-13-2014, 01:47 PM   #7 (permalink)
NeilBlanchard
Is your Fit an automatic or manual transmission? If it's the latter, then bump starting will save your starter. I would say 5 seconds is an absolute minimum. It would get too complicated to do it more often.
I would start EOC'ing at the *best* situations, and then add shorter times as you see fit. (No pun intended!)
