Old 06-13-2014, 06:47 PM   #5 (permalink)
Oceanic815
Oceanic815's Avatar
02 Escape - '02 Ford Escape
90 day: 17.99 mpg (US)
87 Comanche - '87 Jeep MJ
90 day: 24.21 mpg (US)
The ride height I can change; it has a 1" puck on top of the coil spring up front and has 1" lift shackles out back. By removing the puck and reverting to the stock shackles I can get a little closer to the profile of the race truck. Since it's a 2wd it has lower springs than the 4wd models; however, several years ago the driver's side leaf gave up and the only replacement I could find was a set of 4wd leafs; the truck has a noticeable rake due to this.
I will see if I can get better pics of the homebrew air dam to post up.
15 Toyota Prius Three with solar roof - rear diffuser
08 Ferd Escape 2wd 4cyl - stock
85 Volvo 245 lowered with IPD springs and Bilsteins
