07-11-2008, 01:33 AM
#18 (permalink)
Formula - '96 Firebird Formula/Trans-Am 90 day: 19.31 mpg (US)
Originally Posted by RH77
Yes, forgot to mention.
In just about anything I drive, (if equipped with a tach) when I see the bump upward in RPM during decel, I know that the DFCO is no longer active, so it's time to bump it down a gear. I try to get it down a gear before then to keep the fuel-cut active.
The problem: 1st gear is generally super-low in cars these days. I'm in a rental Camry 4-cyl right now and L just about stands it on its nose.
Speaking of which, what happened to automatics that just shift STRAIGHT BACK??? On this car I have to go through a maze of side-to-side, front-and-back just to find L. It's frustrating when you want to keep your eyes on the road. /rant
RH77
The funky shifter path is just the "new thing". Also adds a path for manumatics. I remember some 90s Cadillacs having that, and at the time it was so much cooler to slide through that then the typical straight path.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
