Old 06-15-2014, 01:28 PM   #18 (permalink)
Davo53209@yahoo.com
Originally Posted by California98Civic View Post
The 1992-1995 CX did not have lean burn, so it did not have the wideband O2 sensor plugged in just ahread of the CAT in the exhaust minifold. But if you are correct and that part number is the same, then I've learned something too. I guess you could get the CX manifold and use it and still get lean burn because you'll have the wideband O2... have you checked to make sure it's the wideband O2? I think it is 5 wire instead of the 4 wire. I think.
Both parts diagrams & numbers seem to match up for the CX & VX exhaust manifolds as well as the catalytic converter. Like most people, I've been taught to believe that both parts for the VX are somehow different, whereby impacting fuel economy.
Maybe it's the addition of the 5-wire O2 sensor that adds to the significance. This could make an interesting dialogue with the rest of the forum. More thoughts on this would be great.
As a side note, awhile back, I was able to find the 5-wire O2 sensor for under $200.00. I'm just happy that I never plugged it into my current tri-y exhaust manifold. It might have been a waste.
